accessing UDS face variable
Old   September 20, 2005, 06:10
Default accessing UDS face variable
chapelle
I am trying to access UDS value on faces. The function F_UDSI(c,t,i) proposed by Fluent returns always 0 (as if the value were not kept in memory). Has anybody some experience in using this function?
Thanks in advance.
Old   September 20, 2005, 07:55
Default Re: accessing UDS face variable
chapelle
Are the face variables available ONLY at exterior boundaries?
Old   September 20, 2005, 09:37
Alec Eiffel
yes face variables are only available on domain boundaries. For interior cells face values are given by (c0 + c1)/2 where c0 and c1 are the cell values on either side of the face.
Old   September 20, 2005, 10:27
chapelle
thanks. This method is certainly not very accurate for unstructured mesh.
I have tried to evaluate the UDSI variable on the face using the gradient C_UDSI_G. But, some face values get out of the range defined by the surrounding cells.
Apparently, Fluent does not provide Reconstruction Gradient for UDSI variable. Do you know whether there is a simple method to calculate them ?
Old   September 20, 2005, 11:33
Alec Eiffel
there is no easy way to compute the graident but it is possible. have a look at section 5.2.3 on Cell Grid Definitions in the UDF manual. lots of info on getting gradients and face values on unstructured grids. best of luck!
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
