backflow total temperature?
Old   September 25, 2005, 20:59
Default backflow total temperature?
rachid
In my model, i expect a flow outside through the pressure outlet BC. There is a negative pressure on this BC so ı put -15 Pa gauge pressure. (Not zero this time)
But there is an interesting result. When i open the velocity vectors graphics, a flow which is almost parallel to the Pout BC (reversed flow)where i expect the out flow.
From my documents i found out that this can be overcome by using the backflow total temperature option.
So how do i set it up? My operating conditions are as follows:
Pop=101325 Pa Top= 300 K g=9,81 m/s2
My inlet conditions are:
Vin= 1m/s Tin= 400 K
Outlet conditions are:
Pout= -10 Pa (Gauge pressure) Backflow total temp=300 K (??)
Thanks and good work to you all...
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
how to define the backflow total temperature hanjun FLUENT 4 July 17, 2014 04:00
Temperature: operating, total backflow!!!! gina FLUENT 1 August 3, 2010 04:55
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
HELP!!! total temperature of backflow Jack FLUENT 0 October 13, 2005 14:20
