September 27, 2005, 12:28 |
Values at certain reference plains
Hi!
Is Fluent capable to report values at a certain point or reference plane of my geometry? Until now, I am defining a reverence plane when I set up the geometry in gambit. Then, when I want Fluent to return the values of the simulation result at that plane, I am using write -> profiles and select the plane and the type of results. That is the way, I DON'T want to do it in future. Is there any other? Because when I set up the geometry, I don't know, where I do my measurements to compare the values with simulation results. Any help is appreciated! Ralf |
September 27, 2005, 12:35 |
Re: Values at certain reference plains
In fluent you can add points, lines, rakes, surfaces or iso-surfaces. All of those are available under the Surface menu. You can then use any of those to get the values out of the simulation (either write->profiles, or to view them right in fluent use report->surface integrals).
Hope this helps, and good luck, Jason |
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
Mesh Reference Values problem. | rezki | STAR-CCM+ | 7 | July 19, 2010 05:30 |
Reference Values for Air-Foils with high Angle-of-Attack? | hornig | FLUENT | 0 | January 9, 2010 11:11 |
Fluent 2D Reference Values | Adam | FLUENT | 1 | January 16, 2009 02:58 |
Why's FLUENT changing the reference values? | siw | FLUENT | 0 | November 6, 2008 13:17 |
