Graphics with VNC
Old   September 29, 2005, 10:19
Default Graphics with VNC
mAx
Hi, I have a Linux cluster, and I installed VNC for controling the cluster from my XP sation. now I have a problem as Fluent wants to display a typical window (such as residual, contours, etc...) Fluent gives me following message: "error message from graphic function Show_Device_Info: Server doesn't have GLX extension"
When I test fluent without VLC, it runs perfectly Any advices? Thanks mAx
Old   September 30, 2005, 12:40
Default Re: Graphics with VNC
pUl|
Yes, the answer is simple
Xvnc features a minimal X Server without any fancy extensions such as RENDER. For purposes of simplicity, the OpenGL standard is not supported. To get around this problem when using Fluent, start fluent with the switch '-driver x11' like this:
$ fluent 2d -driver x11 &
Of course change the 2d to whatever you use.
Old   October 4, 2005, 03:33
mAx
eh eh eh!!!! perfect! Thank YOu very very much! mAx
ANIMATIONS IN BATCH MODE Arianna FLUENT 1 January 31, 2008 09:04
grid adaption mode NOT selectable via VNC Ralf Schmidt FLUENT 2 May 24, 2006 02:35
How to change and fix the size of graphics window? Rob FLUENT 1 February 7, 2003 10:15
Problem: graphics display in prostar main window Jiaying Xu Siemens 8 February 14, 2002 08:08
