Subtracting 2 volumes
Old   October 4, 2005, 21:03
Default Subtracting 2 volumes
Vidya Raja
Hi, I have an imported geometry of a solid model from ProE and I'm trying to create a cylinder around it and then subtract the volume of the solid from that of the cylinder to get the flow domain within and around the solid. But when I tried to subtarct the two volumes, I get an error message which says " CAN'T OPERATE ON VOLUME 2 WITH ASSOCIATED NON- REAL GEOMETRY". What does this mean and is there a way to solve this problem?
Please reply.
Thanks, Vidya
Old   October 4, 2005, 21:16
Default Re: Subtracting 2 volumes
zxaar
it means the volume imported has some virtual elements, gambit will not allow you to substract virtual volume from real one and give you a real volume. it seems that when you import gambit creates this. try importing in another form, till you get completely real volume after import. Avoid virtual volumes as much as possible, since they restrict lot of operations. Use virtual volumes only in the end when you are sure that everything is fine and you just need to mesh. Virtual volumes are great help in meshing, but not good help in preparing geometry for meshing.
Old   October 5, 2005, 02:34
Sachin
In case you are not be able to get the real volumes through pro-e, just import the major dimentions and by extruding it in gambit you can easily made the volume. OR delete the virtual volume keeping lower geometry alive. and produce the volume again this will solve youir problem.
Old   October 5, 2005, 15:25
Vidya Raja
If I retain the LOWE GEOMETRY option, and delete the cylinder, how will I produce it again for meshing? How can I create the symmetry plane, split it and do all thos eoperations?
Old   October 5, 2005, 17:47
zxaar
i think what he means is delte only the volume but not the surfaces and vertices. Then out of remaining things construct the volume again by stiching the faces. well you can do so, but main problem is if the surface is virtual, then you need to delete them too, and create them again from surrounding edges. finally when you have all real surfaces make the volume out of them. In theory its perfect plan but in practical i doubt, most probably gambit will stop at some operation.
[GAMBIT] Error when Subtracting Volumes ldavis ANSYS Meshing & Geometry 4 August 26, 2010 10:23
Ansys hang subtracting volumes Aco1000 ANSYS 0 July 14, 2010 08:57
Subtracting volumes imported from ProE Vidya Raja Main CFD Forum 5 October 7, 2005 09:52
Alternate method to subtracting volumes? Daniel Lee FLUENT 2 July 25, 2005 08:58
Subtracting volumes Ng FLUENT 1 March 29, 2005 04:11
