Heat exchanger
Old   October 5, 2005, 12:48
Default Heat exchanger
Andrea
I'm Andrea from Italy.
I have to simulate a heat exchanger. A simple example: 2 different flows (1 at 1000K and the other at 300k). They are divided by a solid, thikness 5 mm. I mesh fluid regions (2) and solid region (1). When I simulate, no heat exchange between cold and hot. Hot flow at 1000K, cold flow at 300K and solid at 700K (but no convection visible!). I'm wrong (I think) in the shell conduction and in the wall properties. Someone could help me? Some tutorials available for understading the problem??
Thx Andrea
Old   October 5, 2005, 23:07
Default Re: Heat exchanger
ZQX
i think it's an unsteady modle. and you donot need to bulid a solid region. you could set a wall between two fluid regions. then in fluent you could set the thinkness of the wall. maybe it helps.
Old   October 6, 2005, 02:49
Andrea
No, I can't use fluent for this example. I have a winged heat exchanger. What do I have to do?
Andrea
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 01:29
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 13:52
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 15:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
