URGENT UDF's erosion_macro problem
Old   October 14, 2005, 11:33
Default URGENT UDF's erosion_macro problem
alex
I am working on surface erosion model. Its erosion is caused by injection of inert particulas on steam flow. Several equations exist to modeling the erosion process and I need to verify them. To obtain it, I must create its UDF's codes. The problem is I don't known how to use the F_STORAGE_R(f function, t, SV_DPMS_EROSION) to store the results from my equations. On the tutorial, I haven't found a complete explanation about this storage function. How I should used this function?
The UDF code for one equation is:
#include "udf.h" float n = 2.6; float K = 2e-09; DEFINE_DPM_EROSION(dnv_haugen, p, t, f, normal, alpha, Vmag, mdot) { real erosion; real alpha; real Vmag; real F_alpha;
F_alpha = ((5.86905e-02*alpha)-(1.05707e-03*pow(alpha,2.0))+(5.18692e-06*pow(alpha,3.0)));
erosion = (K*F_alpha*pow(Vmag,n));
F_STORAGE_R(f,t,SV_DPMS_EROSION) = erosion; {this is the problem} }
How I can store the "erosion" solution?
Old   October 14, 2005, 17:02
Default Re: URGENT UDF's erosion_macro problem
Alec Eiffel
What you have written is correct.
F_STORAGE_R(f,t,SV_DPMS_EROSION) = erosion will store the "erosion" value in FLUENTs erosoin solver variable. To accces the value you have calculated using UDF in FLUENT simply go to display contours and select erosion under DPM variables.
Alternatively you could store the "erosion" value in a user defined memory using:
F_UDMI(f,t,0) = erosion;
C_UDMI(c,ct,0) = F_UDMI(f,t,0);
hope this helps!
Old   October 14, 2005, 18:32
alex
thanks for your suggest, really I agree your help because my proyect is temporally stopped due this problem. I'll prove one more time and I'll try with your additional suggestions.
yours faithfully, ALEX
Old   October 17, 2005, 13:59
alex
I have another question. Are the ways to compile or interpret different in each version? If it's true, which is better way to use my UDF: compiled or interpreted?
Old   October 17, 2005, 15:01
Alec Eiffel
do you mean the version of FLUENT or UDF?
If UDF, then the compiling or interpreting is the same.
Compiling is the better way to use as it runs quicker. You will however need to install Visuall c++ to compile in windows.
Old   October 18, 2005, 09:21
alex
Thanks Alec, really you have helped me much. I'm going to compile the UDF to prove your suggestion.
greetings, ALEX
Old   October 18, 2005, 11:53
alex
Hi, Can you help me to interpret the next message? it's reported by Fluent when I press "build" on the compiled panel:
1 file copied. (system "move user_nt.udf libudf\ntx86\3d")0 (system "copy C:\Fuenlt.Inc\fluent6.1\src\makefile_nt.udf libudf\ntx86\3d\makefile") 1 file copied. 0 (chdir "libudf")() (chdir "ntx86\3d")() "nmake is not recognized like internal or external commando feasible program or batch file. "nmake is not recognized like internal or external commando feasible program or batch file. Done.
Next to it, when I try to load the library on the same panel, the next message was displayed:
Opening library "libudf"... Error: Open_udf_library: The system can not found the specified file. Error Object: ()
Can you help me to solve this problem? Is common the first message displayed?
Old   October 18, 2005, 18:18
Alec Eiffel
http://www.fluentusers.com/support/i...udf_serial.htm
Please help!!!COMPILED UDFs PROBLEM!!! Melih Fluent UDF and Scheme Programming 9 August 2, 2013 01:56
Urgent Help !!!Strange reverse flow in naca0012 problem parvez2683 FLUENT 5 May 20, 2013 09:25
Problem about multi-phase analysis (Urgent) Prof. Lau (PolyU) CFX 2 February 9, 2007 17:59
Urgent problem - orthotropic material in ICEM Luk CFX 6 August 30, 2006 08:06
Multiphase Problem (Urgent) Dadang CFX 4 June 21, 2004 07:46
