November 1, 2005, 02:20 |
TUI and phase-domain
I am trying to set properties (material and droplet-diameter) in a secondary phase with text commands. This fails. For a case with only fluid as possible material type the following works fine (droplet-diameter=0.03):
define phases phase-domain phase-2 phasename yes materialname no constant 0.03 constant 0.0 For a case where both mixture and fluid are possible material types, I had the impression that the follwing should work: define phases phase-domain phase-2 phasename mixture yes materialname no constant 0.03 constant 0.0 I get this error message: Error: CDR: invalid argument [1]: wrong type [not a pair] and I believe the error has something to do about the changing of material. I have checked that the material is properly defined and that materialname matches the name of a defined material. Any help would be appreciated. Especially since the support team at Fluent 'politely' told me that they do not do support on text commands. Sincerely, Jan Erik |
Patching with TUI | Lovermore | FLUENT | 1 | July 22, 2010 22:28 |
