October 22, 2005, 06:08 |
importing vertex data
I am very new to this (doing a project at college), so please excuse the stupid question: I am trying to import the coordinates of a turbine blade into gambit, using import>vertex data. The coordinates are in a text file in two columns, separated by a tab, as x and y (x running from the LE to TE on the suction surface and back to the LE on the pressure surface). When I try to import this, gambit tells me it's assuming raw point input, and I get an "error reading point data" somewhere part way through the file. Can anybody tell me what the correct format of the text file should be, or how else I can import these coordinates? Any help would be much appreciated.
October 22, 2005, 06:13 |
Re: importing vertex data
Sorry, just figured it out: I didn't give it any z-coordinates! Apologies again for wasting time.
November 4, 2005, 01:12 |
I have had some problems similar to yours, have you tried to add a third column of zeros to the tab deliminated file to represent the z coordinates for the points? I have had some luck in doing so. Good Luck.
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
