[Sponsors] | |||||
Hi everybody; after my first simulation I adapted one part of my geometry and replayed my simulation with that finer grid.My question is after this adaptation do I have to Initialize or not? and for example I want to write velocity values on another graph insted of writing on previous graph to compare the differences.What should I do? Thanks
You should not have to initialize. If you want to compare the velocity profiles, you could make an XY plot of the velocity values and write them to file. Then, when you have the new set of calculations, you can do another XY plot, and also read in the old XY plot that you saved. This will display the two profiles on the same graph.
Ok jeremy thanks for your reply. Bye
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| msh format | Frank | FLUENT | 1 | June 27, 2012 10:39 |
| number of nodes and adapted lenghts | fofo | ANSYS Meshing & Geometry | 0 | November 15, 2009 04:05 |
| msh | daniel | FLUENT | 2 | July 17, 2008 05:31 |
| MSH Import | Vivek Vasudevan | FLUENT | 6 | March 30, 2007 10:53 |
| MSH file import | Vivek Vasudevan | Main CFD Forum | 2 | March 19, 2007 20:03 |
