"unassigned interface_zones" Problem
Like Tree5Likes
  • 5 Post By Alec Eiffel
Old   November 26, 2005, 10:35
Default "unassigned interface_zones" Problem
Soheyl
I am using a 3-d grid created in gambit. I have 1 interface boundary. When I want to initialize the problem, it results in the following error:
WARNING: Unassigned interface zone detected for interface 4 Error: Init_Flow: unassigned interface_zones Error Object: ()
What's the problem?
Old   November 26, 2005, 11:39
Default Re: "unassigned interface_zones" Problem
Alec Eiffel
To define an interface you will require two interface boundary conditions (one on either side of the interface). When mesh is imported to FLUENT the interface must be defined using the define->grid interfaces menu. This tells FLUENT which interfaces to interpolate the data between.
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
