Compute Torque on Rotational Model
Old   November 29, 2005, 19:15
Default Compute Torque on Rotational Model
rachid
Hello again,
Is it possible to print the torque applied by the fluid on a rotational model such as an impeller or a wind turbine?
Conventional type of analysis is to input the angular velocity "w" , in this case it is all confusing because the rotation is caused by the fluid flow.
Old   November 30, 2005, 04:42
Default Re: Compute Torque on Rotational Model
bharat
Hi Rachid, Try Report->moments option in fluent. You have specify the zone and the moment center.
hope this helps bharat
Old   November 30, 2005, 11:53
rachid
Thank you Bharat.
Yet there is one thing still i am not sure. If we are to design the analysis with the angular velocity input, how can we manage to read the moment that is caused by the wind? I mean i am thinking the wind speed is variable and other parameters like w, M, etc. is the output, since the model geometry is constant for each case.
Just in case if i change the wind velocity magnitude to see the effects on the moment around the windmill center.
Thanks again...
Old   November 30, 2005, 19:25
bharat
Hi Rachid, I assume that u r using MRF model of fluent. In that case the moment u get by report-moment would be the moment felt by the blades for the angular velocity and wind speed u r inputting. Since MRF is a steady state model, i will give u reasonable moment felt by the blades.
Old   December 1, 2005, 10:51
rachid
Yes MRF is used. Then this is the answer.
One last thing. In this case angular velocity input becomes very important i mean the exact value must be obtained from experiment because any other value should not make sense as even the wind is flowing through the blades we try to hold the shaft to slow down. Is this right?
By the way thanks for your time...
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Rotational flow turbulence model ntrask OpenFOAM Running, Solving & CFD 3 February 3, 2009 10:59
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
