to imporat different meshed volumes in fluent |
November 23, 2005, 05:28 |
I have generated mesh of a silencer in Ansys ICEM CFD. Now i am trying to import it in fluent. The problem is that i have done meshing for different volumes in silencer.i.e. in silencer there are three meshed volumes. So whenever I am importing it in fluent it takes only one meshed volume at each time .i.e.,suppose i have imported inlet side meshed volume then i want to import another side volume then it asks that the current case has not been saved so we have saved it by command Write/Autosave. Still it gives same warning. Can you provide solution for that? i want to know that how i can import different meshed volumes to fluent. thanks
November 23, 2005, 07:33 |
Re: to imporat different meshed volumes in fluent
Hi, You must use "tmerge". You can import *.msh files and merge them. At the system prompt, type: utility tmerge -3d Hope it helps. Max
November 23, 2005, 11:35 |
Use TGrid or tmerge as max stated. There is an example of using tmerge in the fluent tutorial for a non-conformal interface. That might help you.
November 23, 2005, 23:35 |
Or you can use merge mesh option in Icem. There u can merge hex & tet avoiding any interface. It will create pyras. Check if u r getting good quality.
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
Fidap to Fluent | Ravi | FLUENT | 3 | July 10, 2008 13:31 |
Alternate method to subtracting volumes? | Daniel Lee | FLUENT | 2 | July 25, 2005 08:58 |
