UDF to switch on energy equation after X iteration
Old   December 3, 2005, 11:29
Default UDF to switch on energy equation after X iteration
mat w
Hi all, does anyone have a UDF that I could use to switch on the energy equation on a problem after, say 500 iterations? Or even better, one that switches the energy equation on after the continuity residual hits 1e-6? It would save me lots of time when running problems over night.
Any help or advice much appreciated.
Thanks, mat
Old   December 5, 2005, 01:28
Default Re: UDF to switch on energy equation after X itera
nasser
plz more explain do you want to enable energy equation after 500 iter?
Old   December 5, 2005, 03:40
mat w
That's right nasser - I want to "enable" or turn on the energy equation (Solve-Controls-Solution) after say 500 equations. It would be even better if I could switch on the energy equation after the continuity residuals reduced to below a certain level.
thanks mat
Old   December 5, 2005, 04:23
nasser
Do you use segregated model? if you use this model you can. use under relaxtation method bye
Old   December 5, 2005, 04:36
mat w
I am using a segregated solver, but how will the "under relaxation method" help?
I'm not sure what you mean exactly - a UDF is required in order to automatically enable the energy equation after a certain number of residuals, I'm just not sure how to write it.
Thanks anyway, mat
Old   December 5, 2005, 07:26
steph
Hello, you needn't UDF ... you can use a file.jou :
/file/read-case toto.cas.gz
/file/read-data toto.dat.gz
;; you do 500 iterations ...
/solve/iterate 500
;; ... after you switch on energy equation
/define/models/energy? yes
/solve/iterate 1500
/file/write-data toto_end.dat.gz
steph.
Old   December 5, 2005, 07:35
mat w
Steph,
Thanks for that-sounds good. I'll give it a whirl.
Cheers for the help - it'll save me lots of time.
Mat w
simpleFoam with energy equation sega OpenFOAM Programming & Development 6 January 26, 2013 06:42
Pohlhausen energy equation MATLAB help abe_cooldude Main CFD Forum 2 May 3, 2010 16:58
How to discretize of energy equation ?? Asghari FLUENT 0 October 12, 2006 08:09
How to discretize of energy equation ?? Asghari FLUENT 0 October 12, 2006 08:06
UDF sources for energy equation el FLUENT 0 July 1, 2005 08:38
