Blassius Flat plate Solution
Old   December 2, 2005, 07:23
Default Blassius Flat plate Solution
erdem
Hi everyone
I'm using Fluent for my masters thesis which is about external car aerodynamics. before starting my 3D cases I want to validate the Blassius's analytical solution for flow on a flat plate(2D). as everyone knows the flow becomes turbulent after a certain Re number (5e+5). so I don't know which turbulence model to use because the flow is laminar+turbulent. can anyone help me ?
Old   December 2, 2005, 09:22
Default Re: Blassius Flat plate Solution
Matt
Laminar to turbulent transition is a difficult thing to model. In Fluent, you either are laminar OR turbulent, not both.
In aerospace applications they usually use a turbulence model but use a very low freestream value for turbulent kinetic energy (quasi-laminar). They then patch a spot of kinetic energy to 'kick' the BL into turbulent transition. There is a lot of research going on for models to incorporate this transition.
The thing for you to do might be to apply a turbulent Blasius profile at the inlet of the domain and solve with a turbulence model, and verify that the non-dimensional BL properties far downstream still conform to the Blasius solution.
drag of flat plate with cavity Far FLUENT 0 May 18, 2010 04:57
DNS for Impinging Jet on a Flat Plate Chandra Shekhar Main CFD Forum 3 January 18, 2010 05:03
meshing over a flat plate bhanu kishan Main CFD Forum 1 February 7, 2009 14:45
Flat Plate Drag & Lift Joe Main CFD Forum 3 October 24, 2008 14:17
Flat Plate And LES Chetan Kadakia FLUENT 0 December 2, 2001 21:44
