December 13, 2005, 05:08 |
Urgent! Help Needed
Dear All,
Could you tell me how to add a source term in to the Y mom. Eq.? Could you forward me some piece of UDF program? Thank you very much in advance. Rucy |
December 14, 2005, 03:46 |
Re: Urgent! Help Needed
You can find it in the define menu. define->boundary conditions. A panel will open, in which there are two columns, in the right column select the zone you want to add the source. Push the "set" button and there will be a new panel. In the panel just select the source term. you will find the Y mom Eq, select the fucntion you define, that is OK.
DEFINE_SOURCE(example, c, t) { float source; float pp, tt, xx; pp = C_P(c,t); tt = C_T(c,t); xx = C_U(c,t); source = pp*tt/xx; return source; } |
December 14, 2005, 07:52 |
Dear Sir,
Thank you very much. Could you tell me how to find the related manual of Fluent, or any related information, to write UDF? I still do not know the meaning of: (example, c, t) ? Any way, thank you very much. Rucy |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 15:22 |
help needed in Turbulent flow (URGENT) | mike | FLUENT | 7 | November 7, 2008 06:11 |
Urgent help needed with spray injection | nick | Siemens | 14 | June 29, 2008 18:48 |
Urgent Help Needed! | Ken Adams | FLUENT | 3 | September 25, 2007 23:50 |
urgent help needed on dpm | vaishali | FLUENT | 3 | December 18, 2006 14:20 |
