unsteadiness
Old   December 30, 2005, 14:02
Default unsteadiness
tucker
I am having difficulty capturing the unsteadiness of a jet spray in Fluent. I've selected the unsteady option in the solver model menu and I'm using the k-epsilon viscosity model. Jet sprays are typically very unsteady and I'm using a significantly high Reynolds number (184,000), yet each of my time-steps gives me a nice, symmetric, smoothly-varying velocity contour plot. I've even initially disturbed the flow, but with no success.
Have any of you ever encountered this before or do you have any tips to better capture unsteadiness. I would greatly appreciate any and all advice. Thanks!
Tucker
Old   December 30, 2005, 22:44
Default Re: unsteadiness
Muhammad Shakaib
Although I have not modelled the jet spray. But I think you can try two things: (i) define surface monitors at different locations in your domain and see whether there is change of velocity with time
(ii) Change the grid size (increase the no. of cells)and try to capture the unsteadiness.
Convegence problems while increasing the mesh resolution Marcin OpenFOAM 12 May 20, 2009 02:05
Two questions! Daniel Main CFD Forum 2 January 19, 2008 22:06
Information for onset of unsteadiness diaw Main CFD Forum 10 October 24, 2005 01:55
Unsteadiness of the problem pp FLUENT 9 March 15, 2005 10:15
stagged grid solution is high of numer viscosity? HT Main CFD Forum 13 March 4, 2004 12:26
