which model suits for pitching aerofoil
Old   December 24, 2005, 00:24
Default which model suits for pitching aerofoil
GOVINDARAJU L
As I'm dong my Masters project work on the Turbulent pitching past a NACA0012 Aerofoil, and I used low-Reynolds model by Chien, V2f, and std-wall(k-e),problem is none of the method is predicting with the experimental data, except the V2f-model, so plz kindly suggest me, as i;m in a trouble. Thanks in well advance...
Old   January 5, 2006, 12:23
Default Re: which model suits for pitching aerofoil
sharuk
did u fit any boundary layer around, and check ur y+ value too.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
