Initial condition of fluid within domain
Old   January 2, 2006, 09:10
Default Initial condition of fluid within domain
Gene
Hi, i am new to CFD as well as Fluent. I have created a 2D model to simulate natural convection within a vertical channel. Within the channel, I have a wall emiting constant heat flux, a pressure inlet at the bottom of the channel and a pressure outlet at the top of the channel, pressure of this 2 channels are at atmospheric pressure (101325 pascal) and temperature of 293K.
How do i go about setting the pressure of fluid within the channel plate to be at atmospheric pressure and the temperature to be 293K initially?
Kindly assist and thank you.
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 02:18
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
MRFSimpleFoam amp cyclic patches david OpenFOAM Running, Solving & CFD 36 October 21, 2008 21:55
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
