Constant turbulent viscosity
Old   January 12, 2006, 08:00
Default Constant turbulent viscosity
Q
I am simulating frozen turbulence case. I am not solving for k and epsilon. I want to know is it possible that I can switch off the Wall functions for momentum equation. How can I switch off the wall functions
Q
Old   January 18, 2006, 05:20
Default Re: Constant turbulent viscosity
kharicha
Use "enhanced wall treatement" this cancel the use of wall functions, but then it resolves the boundary layer. To avoid the resolution use a zero shear stress at the boundary walls.
I hope it solves your problem. Make me aware if it works.
Abdellah
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
