Use custmer defined function to calculate Re
Old   January 24, 2006, 06:14
Default Use custmer defined function to calculate Re
peter
I used a pressure inlet and pressure outlet bc for inlet and outlet respectively in a 2d case, i want to use the simulated velocity at inlet to calculate the Reynolds number, so i use coustmer defined function panel, and I chose "select operand field function from (VELOCITY->Velocity Magnitude )*(GRID->Y coordinates)/(PROPERTIES->Molecular viscosity), this means U*D(pipe width)/viscosity, but the results seems not right. any one who konw how to do this? or anyother easier method? thanks you very much
Old   January 24, 2006, 08:39
Default Re: Use custmer defined function to calculate Re
Mario
Try the following definition: Re = U*D*density/viscosity
I think you have mixed up dynamic and kinematic viscosity. In your equation "viscosity" represents the kinematic viscosity but Fluent provides the dynamic viscosity.
kinematic visc = dynamic visc / density
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
User defined function hari FLUENT 0 October 9, 2007 03:24
How to create an user defined function? Cagdas FLUENT 1 September 5, 2007 20:02
