January 21, 2006, 05:49 |
Injection in DPM
Dear Friends: when i wanna define an injection of droplets; fluent need "velocity" and "mass flow rate". I think, when i have droplet properties and its velocity,mass flow rate is determined.I mean only "velocity" or "mass flow rate" must be specified as input. Is it true? regards masood
January 21, 2006, 06:55 |
Re: Injection in DPM
You have to define velocity, mass flow rate and the co-ordinates from where you want to inject fuel.
January 21, 2006, 10:08 |
Dear MANOJKUMAR:
Thanks for reply,but i said that i think only "velocity" or "mass flow rate" is need for injection.because: mass flow rate= density*velocity*cross sectional area i mean when i have "velocity" no need to define "mass flow rate". is it true? regards |
January 23, 2006, 03:41 |
No because with the mass flow rate, you couldn't know the direction of the flow.
So you need: - the mass flow rate, - velocity in x,y,z cooridantes, - diameter of particules |
January 23, 2006, 23:55 |
No u must give the direction of the particle means u have to define co-ordinate and mass flow rate, and all thing which given in tha properties and also give the no of tries in the next steps. MANOJKUMAR
DPM injection model selection | dokeun | FLUENT | 5 | September 6, 2010 03:27 |
Dense DPM Injection Help (basic sedimentation) | sgelman | FLUENT | 0 | July 21, 2010 14:19 |
On DPM injection properties. | akr | FLUENT | 4 | October 23, 2006 10:54 |
DPM, UDF, Injection Type | Zhang | FLUENT | 0 | June 8, 2005 15:51 |
DPM Injection Parameters | Hendawi | FLUENT | 0 | June 13, 2002 09:41 |
