UDF for rotating wall
Old   January 30, 2006, 11:03
Default UDF for rotating wall
Philippe
Hello. I'm trying to program a UDF to simulate the rotation of a boundary in my Fluent model. The geometry I'm trying to create is an inverted cone (cone apex at the bottom, cone base at the top) rotating above a flat plate. Fluid flows within the gap between the cone surface and the plate. The cone rotates at an angular velocity that is time-dependent and periodic but that cannot be expressed as or approximated by a simple function (like a polynomial, exponential, logarithmic, etc). I was thinking about decomposing the function into a FFT and then using an inverse FFT in a UDF in order to extract the value at the current time. I really have no clue about how to do that. If you have any other suggestion or if you think you might be able to help, please let me know. Thank you!
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
UDF for slip and moving wall lichun Dong FLUENT 3 March 26, 2014 04:37
wall suction udf osman turan FLUENT 2 July 17, 2008 07:09
UDF hook on the WALL boundary condition Luke FLUENT 0 June 7, 2006 11:54
udf: dimensionless wall coordinate Chris FLUENT 0 June 22, 2004 06:10
