input variable properties of new materials
Old   January 27, 2006, 05:22
Default input variable properties of new materials
ABHISHEK YADU
sir, i am unable to understand how can i add new material property which is variable. Let me Define the problem clearly i am using new fluid and property of this new fluid is changing with respect to temperature and pressure. in my CFD simulation pressure is constant but temperature is changing from 300 to 1000 deg.and i want that during CFD simulation that should be used by fluent to get accurate result like heat transfer, density plot or any other plot. so how can i do this . thanks
Old   January 31, 2006, 07:45
Default Re: input variable properties of new materials
HS
This can easily be done in the Materials-panel for most properties. Standard ways of doing this is as piecewise linear or piecewise polynomial functions. If you already have an expression for the property then the easiest way is probably through a user-defined function. Good luck!
/Henrik
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
