Convergence issues with long period sloshing flows
Old   February 1, 2006, 07:41
Default Convergence issues with long period sloshing flows
Brian
Does anyone know any tricks to get my solution to converge for a long period (~15 secs) sloshing flow? The excitation of the domain is just some A * sin (2*Pi/T * time). If my period is long then the solution (moment time history) doesn't look smooth. If I shorten it then things look great and match theory. Any suggestions?
Old   February 1, 2006, 08:41
Default Re: Convergence issues with long period sloshing f
edi
By period do you mean the flow time? In this case the moment time history couldn't look smooth because of non-linear effects due to the interaction between the frequency 1/T of your excitation and the natural frequency of the fluid in the tank. As long as your solution converges well (preferably within 10 or less iterations) every time step, I never found unrealistic results...
Hope this helps
Edi.
Bouyancy-driven flows and convergence Marcello Caciolo Main CFD Forum 17 February 14, 2018 19:34
Laminar Pipe Flow convergence issues preichl OpenFOAM Running, Solving & CFD 11 September 22, 2014 21:22
continuity convergence in buoyancy driven flows brossofor FLUENT 0 March 29, 2011 04:31
Grid size, convergence issues franzdrs Main CFD Forum 3 June 18, 2009 07:57
Problems with convergence and initial guessed fields in compressible steady flows Pedro Gil Main CFD Forum 3 April 25, 2000 11:34
