Printing Values on a Specific Surface
Old   February 7, 2006, 17:39
Default Printing Values on a Specific Surface
Matthew
I wish to obtain a list of pressure values on a particular wall surface. So far i am only able to obtain an XY plot of pressure against X coordinate, for the particular wall surface i am interested in. Instead of a graph i would like a print out of actual pressure values with their corresponding coordinates (ie the numeric data used to construct the XY plot).
The reason i wish to obtain these values is to ultimately determine the location of the centre of pressure. The object i am dealing with is essentially a stationary 2D square in a flow of air. Using the pressure values, i will use Excel to numerically integrate to ultimately determine the centre of pressure. Is there a simpler way to do this within FLUENT? For example using surface integrals etc.
All help appreciated, Matthew
Old   February 8, 2006, 08:15
Default Re: Printing Values on a Specific Surface
Jason
Export and ascii file (File->Export, Choose ASCII under File Type, pick the surfaces under Surfaces, and pick Static Pressure and the coordinates under Functions to write).
Hope this helps, and good luck, Jason
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Acessing neighbouring values in specific directions RoE OpenFOAM 10 October 4, 2012 03:38
printing values from udf!!! Shekhar FLUENT 2 January 13, 2004 11:49
