Interpolation Query
Old   February 10, 2006, 05:48
Default Interpolation Query
Hrishikesh
I am reposting my question
I want to use the results of nozzle fluid flow in another assembly simulation using interpolation option. It is given in the manual that the parameters of both geometries must be same. After reading the interpolation file, I am not getting the nozzle results same as done by separate analysis. Can anybody tell me the probable causes and remedies? Also I am having the following doubts
1) Is it necessary to keep the co-ordinates of nozzle used in assembly drawing as that of the nozzle separately analysed?
2) I have defined separately analysed nozzle inlet & exit as pressure inlet & outlet and assembly nozzle inlet & outlet as interior. Is it permissible? (Though my inlet pressure at assembly nozzle inlet is same as that at separately analysed nozzle, my actual pressure inlet in assembly is not at nozzle inlet, hence I used interior)
3) Is any other specific operations (like profile reading or separaing faces)to be done after reading interpolation file?
Help on 2D interpolation in StarCCM+ madhuri Siemens 1 May 30, 2017 03:20
Interpolation Error on FAM Mesh with Cyclic BCs ngj OpenFOAM Bugs 1 August 9, 2011 06:12
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 14:32
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
