February 13, 2006, 09:07 |
turbulent buoyant plume
Hi
I'm trying to simulate the evolution of a buoyancy plume and I wonder which model I should use. The configuration is the following : a light fluid (fresh water) is injected into a tank filled with a heavier fluid (salt water). Both fluids have the same temperature. Should I used a Multiphase model or is there a way to define a mass flow inlet at a specificc density ? Thanks Theo |
Swirling axisymmetric buoyant plume | ic7 | FLUENT | 1 | April 18, 2010 23:27 |
oscillating pressure residuals buoyant plume | mabinty | OpenFOAM Running, Solving & CFD | 0 | August 31, 2009 05:31 |
Buoyant turbulent flows | Sudhir | FLUENT | 3 | March 16, 2009 06:52 |
Buoyant plume source | Iona Evans | CFX | 0 | February 27, 2008 07:29 |
Modeling Turbulent Horizontal Buoyant Jets | Jack Travis | Main CFD Forum | 2 | September 11, 2006 06:36 |
