Can't figure which cell particle is going to -- AB
Old   February 21, 2006, 18:13
Default Can't figure which cell particle is going to -- AB
am
Dear All,
I'd never seen this msg."Can't figure which cell particle is going to -- ABORT" .Anyone have any ideas what's the reason?
I injected fuel and moisture on the same (plane+bounded) surface.I'd run the same method like this before but the difference is at first case, i've created the surface in the gambit and set it as a wall in BC. Then, i injected the fuel and moisture from the plane.
I would like to hear any advice/suggestion.Thanks in advance.
-Am-
Can't figure which cell particle is going to rookie FLUENT 3 December 8, 2017 09:07
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
Can't figure which cell particle is going to? Easycad FLUENT 4 November 13, 2003 07:18
