Mass diffusion of surface exposed to water flow
Old   February 24, 2006, 12:54
Default Mass diffusion of surface exposed to water flow
Derek
I'm modeling a fairly simple scenerio in Fluent. I have a rectangular channel (55mm x 2mm x 4mm LxWxH). Along one wall (4mm) I have a dissolvable tablet (4mm x 2mm LxH). Water is the fluid flowing thru the channel. There is no chemical reaction between the solid and the water, only dissolution. In setting up the species transport, do I select water as the "Selected species" and the solid as the "selected solid species?" This is assuming I'm using wall surface reaction model. I'm fine with setting material properties and boundary conditions, however my final question is how to make my fluid water (under boundary conditions)?? It has been defaulting to air (I believe) and I have been unable to change it to water. Do I need to specify my inlet condition mass fraction as 100% water? Or is there another way? Thanks in advance
Old   February 24, 2006, 15:01
Default Re: Mass diffusion of surface exposed to water flo
A
1- define bc 2- fluid set then select water as your fluid, assuming you have copied water from Fluent Data base
Old   February 24, 2006, 15:43
Derek
When species transport is turned on, the option to pick the fluid type is not under 'fluid' in the bc menu. So I'm assuming there is another way to set the fluid as water?
Old   February 27, 2006, 14:38
A
data input panels depend on the models selected, the last time I solved a similar situation was months ago, I remember having to specify each component as spieces 1 or 2 ...and you define the concentrayion for each. Sorry if I am not of more help. Cheers and good luck
Mass flow rate through each cell Babakjingo Main CFD Forum 0 August 21, 2011 03:18
heat and mass transfer durin water evaporation from wet surface yigitktu FLUENT 0 September 22, 2010 08:04
Mass Flow Rate on the Interior Surface Barii.Johnason FLUENT 24 May 11, 2007 17:59
different mass flow rates michael FLUENT 4 February 21, 2005 03:48
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
