March 3, 2006, 02:43 |
meshing a geometry
I have a small doubt. If we are meshing a 2D geometry, then, can we mesh one face using quadra mesh and other with triangular mesh? I hope u understood my question. If any clarifications are required I will do it. Thanks in advance |
March 3, 2006, 04:54 |
Re: meshing a geometry
if you mean, you have 2 faces connected each other, than yes you can mesh one with quad and the othe with tri
March 3, 2006, 06:04 |
Thanks for your information |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
Need help on meshing this simple geometry | nha1g08 | ANSYS Meshing & Geometry | 3 | March 9, 2011 02:13 |
Meshing on simple geometry | pukiwawa | FLUENT | 5 | August 31, 2008 12:04 |
Problem meshing turb. blade tip clearance geometry | Balu | FLUENT | 0 | June 7, 2008 21:10 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
