how to solve turbulent viscosity limited ?
Old   March 7, 2006, 00:02
Default how to solve turbulent viscosity limited ?
daniel sin
anyone know it? turbulent viscosity limited to viscosity ration of 1.000e5 in 123 cells
Old   March 7, 2006, 02:02
Default Re: how to solve turbulent viscosity limited ?
Rizwan
check your initialized values. the turbulent viscosity and dissipation values should be very low. refer to fluet help files tutorial guide on boundary conditions and calculation for turbulence quatities.
hope this helps.
Old   March 7, 2006, 02:13
CFD
Increase limit of turbulent viscosity from 100000 to 1000000 in the panel solve-->control-->limits.
Hope this help.
Old   March 7, 2006, 02:15
Rajesh
Another useful information:
http://www.cfd-online.com/Forum/flue...cgi?read=29389
Rajesh
Old   March 7, 2006, 14:22
Freeman
I think increasing the limit is not a good idea since you will be only "postposing" the warning message: I mean, if you increase the limit, solver would increase each iteration the turbulent viscosity. Perhaps you might not be noticed again about the warning, but in the final calculation your turbulent viscosity would be, i.g. 500,000 and if your fluid is water, this turbulent viscosity would be indicating that your fluid at the turbulence state is almost cement!
The explanation given by zxaar time ago that Rajesh has recovered in a link again was (and it is) simply great.
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 22:54
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 08:57
Turbulent viscosity limited to viscosity... Cyril FLUENT 16 October 4, 2007 06:12
turbulent viscosity limited to viscosity ratio mukkarum FLUENT 3 May 11, 2004 04:05
Turbulent Viscosity Ratio xiang FLUENT 3 May 20, 2003 12:46
