UDF for mass difusivity
Old   March 9, 2006, 08:51
Default UDF for mass difusivity
Jiri Novak
I am simulating multicomponent flow using SPECIES. I set the temperature dependent diffusivity for mixture under material s .. which causes an initialization error:
warning mass_diffusivity: invalid(zero) diffusivity phase check material properties.
Does anyone know why and why the mass diffusivity is set for mixture instead of pure species?
My simply UDF looks: DEFINE_PROPERTY(diffusivity, cell, thread) { real diff; real temp = C_T(cell, thread); diff = 6.5e-6 * exp (-20000/temp); return diff; }
Thanx Jiri
Old   March 9, 2006, 09:31
Default Re: UDF for mass difusivity
RoM
For a temperature of 300K your udf will return 7.2e-35. Fluent wont take such small values and simply set is to zero which causes the error. Even for 2000K the return value is 3e-10 which is very small. Are you shure you function is correct? Adding the exp function to 6.5e-6 instead of multiplying seems to produce more reasonable results...
RoM
Old   March 9, 2006, 12:17
Jiri Novak
Thank you. I haven't tested this yet. So, I'm gonna to split the UDF into two regions providing realistic values and not loosing the temperature dependent character.
Regards Jiri
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
