Questions About Surface-Tension Driven flow
Old   March 9, 2006, 00:31
Default Questions About Surface-Tension Driven flow
moki
First! In the Fluent, Can Surface-Tension Driven flow problems be simulated?
Old   March 9, 2006, 03:02
Default Re: Questions About Surface-Tension Driven flow
edi
Yes. The most common multiphase model adopted for such cases is VOF.
Hope this helps
Edi.
Old   March 12, 2006, 19:26
moki
Thank you for your answer. But I can't handle this case.
If you have ever tried this kind of case, would U give me a case file or something like that?
Bye!
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Looking for software for free surface flow Eric Jiang Main CFD Forum 12 December 17, 2007 23:39
two phase flow with surface tension qunwuhe@hotmail.com Main CFD Forum 2 October 21, 2007 00:29
Free Surface Gravity Driven Flow Rupp Carriveau FLUENT 4 June 14, 2001 16:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
