particle body force and scalar update.
Old   March 21, 2006, 06:53
Default particle body force and scalar update.
Kasper Skriver
Hi
I'm looking on particle transport between two plates subjected to a potential diff of 10kV.
The potential between the two plates has been defined as an user scalar, and calculated with boundary values 0 and 10kV. This is no problem.
The next step is modelling how the particles act in the potential field. First i define a charge of the particle as a scalar update(DEFINE_DPM_SCALAR_UPDATE). Then the body force as an additional acceleration DEFINE_DPM_BODY_FORCE. The code is at the bottom. Compiling works and loading does to.
When using these two UDF's in the discrete phase model I get the following error:
:>> Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () <<<
1. there is nothing but this event. 2. wont help. 3. same same. 4. they are a bit slow The error object is empty, why!!!!
I have an idea that it has something to do with the C_UDSI_G command, but I'm not sure.
Please help
-------------------------------------------- CODE:
#include "udf.h" #include "surf.h"
Particle *p;
DEFINE_DPM_SCALAR_UPDATE(charge,cell,thread,initia lize,p)
real P_charge_density;
if (initialize) /* only if init */
P_charge_density = - 1.e-3; /* [C/kg], if minus => negative charge */
p->user[0] = P_charge_density * P_MASS(p);
DEFINE_DPM_BODY_FORCE(elstat_force,p,i)
cell_t cell = P_CELL(p);
Thread *thread = P_CELL_THREAD(p);
real P_charge;
real NV_VEC(P_accelleration);
P_charge = -1.0 * P_USER_REAL(p,0); /* makes the gradient negativ */
NV_V(P_accelleration, =, C_UDSI_G(cell, thread, 0)); /*Coulomb force*/
NV_S(P_accelleration, *=, P_charge);
NV_S(P_accelleration, /=, P_MASS(p)); /* acceleration required */
return (P_accelleration[i]);
Old   March 21, 2006, 09:55
Default Re: particle body force and scalar update.
RoM
There is nothing wrong with your code except the global "Particel *p;" which is not needed. It runs perfectly well on my machine. Maybe you did not allocate the particle scalar (define->models->discrete phase , in udf tab set number of scalars to 1)
RoM
Adding side force to forceCoeffs.C drrbradford OpenFOAM Programming & Development 25 October 17, 2017 03:12
Tomiyama wall lubrication force Edy OpenFOAM 10 December 13, 2010 11:41
charged particle UDS, UDF JJi Fluent UDF and Scheme Programming 0 May 12, 2009 04:32
model particle movement under magnetic force phsieh2005 Main CFD Forum 8 March 28, 2007 07:12
How to see Scalar Force Datas? Tunc Siemens 1 September 20, 2005 10:24
