VOF method on inter-tank transfer
Old   March 14, 2006, 09:28
Default VOF method on inter-tank transfer
Louis
I'm a doing a final year project on using Fluent's VOF method to simulate inter-tank fuel transfer in aircraft.
The setup just involves two adjacent rectangular tanks with a hole/orifice separating them. One tank has an inlet of water flow into it, and my simulation need to find the flow rate through the hole/orifice for different water level difference (head) between the tanks.
I'm still in the preliminary stages of the simulation, and I've had no luck in searching for literature and studies done previously on this type of problem (using VOF to simulate inter-tank transfer).
Has anyone come across any tank transfer studies using the VOF method?
a problem of incompressible two phases(water and gas) with VOF Method zhangweisnoopy Main CFD Forum 9 August 12, 2011 08:25
How to apply VOF method? yeeking86 CFX 7 August 23, 2010 18:24
Heat and mass transfer in VOF model asghari Main CFD Forum 1 May 7, 2006 13:33
VOF transfer - multiphase flow karthik Main CFD Forum 4 February 2, 2006 01:25
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 08:25
