multiphase about the electrolysis ~ ple help me
Like Tree1Likes
  • 1 Post By Luke
Old   March 12, 2006, 12:53
Default multiphase about the electrolysis ~ ple help me
Luke
hellow everybody:
My name is Luke. I am trying to simulate the chemical reation which is about the multiphase flow (two phase). I consider the liquid-water in a electrolyzer and there are two electrodes in it.
I want to electrolysis the liquid-water and produce the H2 at the surface of cathode and the O2 at the surface of anode. Beside, the mass of the H2O(consumpted), H2(generated) and O2(generated)must to be shown or calculated in my problem.
The simple chemical reaction is below.
H2O(liquid)---->H2(gas) + O2(gas)
This problem is involved with the multiphase and the species transport. Which multiphase model should I choose? And how can I see the phenomenon of the species transport? And how can I calculate the amount of the H2 or O2 which is generated by the chemical reation?
Please help me. Thank you~
gullu likes this.
Old   March 14, 2006, 04:06
Default Re: multiphase about the electrolysis ~ ple help m
Luke
pls help me. Thank you~
Old   March 14, 2006, 08:18
kharicha
Question: do you expect a lot of small bubbles (100-1000) created in the same time or a limited number of big bubbles growing slowly ?
In the first case : use mixture or Euler-Euler model. In the second case use VOF....
your questions are welcome.
Old   March 15, 2006, 12:27
grzesiek
quastion to kharicha What if we have a free surface (like somethinf filled to 1/2 of volume)?
Old   March 16, 2006, 03:47
kharicha
This is a problem!
The only method (in FLUENT)that can deal with a free surface is the VOF method....but this method is not able to model a mixture area.
Presently, I am dealing with a phenomena which is similar to raining over a free surface which I want to exactly track.
For the mixture (rain+air) I use a transport equation which compute the proportion of the rain phase over the gas phase. When the concentration reach the interface i convert the concentration into mass of liquid. So the level of interface is increasing while the concentration is absorbed.
This is valid only if the concentration of rain phase is much smaller than the gas phase (few percent). And the droplet size should be much smaller than your grid size.
But if you are not interested by tracking exactly the interface, you can use the mixture or the Euler-Euler approach, which nevertheless are not so bad for interfaces which are not subject to special phenomena (surface tension, magnetohydrodynamic....etc
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
multiphase flow ,phoenics user forum ismail Phoenics 0 October 23, 2008 19:26
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
