Fluent V6.2 & Parallel & linux
Old   March 19, 2006, 04:50
Default Fluent V6.2 & Parallel & linux
scubme
Hi all:
I had installed fluent_v6.2_linux under RedHat 9.0, but when I run it with paralell mode(fluent 3d -t2), the menu commond "File-Run" is gray and unusable.
What is the reason?
Old   March 19, 2006, 08:25
Default Re: Fluent V6.2 & Parallel & linux
scubme
I had found the reason. If I run only fluent, the RUN commond will be usable.
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
Install Fluent in Linux L3munoz FLUENT 0 July 21, 2009 14:55
Fluent parallel poovanna FLUENT 0 March 23, 2007 23:22
error parallel fluent session Diet FLUENT 2 January 27, 2005 12:31
