UNDER-RELAXTATION FACTORS??????????????????
Old   March 22, 2006, 03:21
Default UNDER-RELAXTATION FACTORS??????????????????
Anne
Hello hello everyone. what is the less UNDER-RELAXTATION FACTORS, to put in solution controls. is there a rule to respect?????????????? thanks.
Old   March 22, 2006, 08:40
Default Re: UNDER-RELAXTATION FACTORS??????????????????
Nick
not really , all you are changing is the ratio of values for subsequent interations. The minimum values I tend to put in are of the order of 0.01 , say my solution is blowing up due to temperature I will reduce the energy to that kind of value and maybe back it off a bit when the solution has calmed down.
Obviously the lower the value the slower your solution will take to converge !
Old   March 24, 2006, 09:03
sean
Hi Nick,
so we can lower the under relaxation factors of all governing equations to such a low value ? In the manual they suggest to reduce, eventually, to about 0.8 the energy equation, 0.2 pressure, 0.5 momentum, k and epsilon.
Thanks for you help,
Best Regards.
Old   March 24, 2006, 09:10
Nick
yes, I regularly reduce these numbers to such small values, I can't say that I have gone beyond this though. One thing to remeber is that you can do, is to increase the underelaxtion ! Say for example that you have a very stable solution you could well up the pressure to 0.4 or so to speed up the convergence, but this will be very model dependant.
Old   March 24, 2006, 11:56
sean
ok, thanks a lot!
but, will the solution be affected by choosing so low values of URF?
Regards.
Relaxation Factors for Transient solvers philippose OpenFOAM Running, Solving & CFD 19 March 20, 2014 04:39
Purpose of relaxation factors Mohsin FLUENT 5 April 30, 2010 11:57
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
False time step factors Jesper Laursen Main CFD Forum 4 June 4, 2002 04:35
Residuals and Under-relaxation factors Ale FLUENT 4 February 14, 2002 08:42
