allways problems with ideal gas
Old   March 31, 2006, 06:14
Default allways problems with ideal gas
Ralf Schmidt
Hi!
I am simulating turbulent gas flow at high temp (400 - 1000 K) and high pressure (10 - 20 bar). When I turn on ideal gas law, I have allway problems with the floating point error.
The same sim. with incomp. ideal gas is working very well.
What are the best settings for ideal gas?? what solver is the best (i am using seg.)? What is the best vel-pressure couling sheme? are there other factors (urf,...)???
Any help is highly appreciated!!
Ralf
Old   March 31, 2006, 10:35
Default Re: allways problems with ideal gas
Thomas
Never use ideal-gas law unless u really need it. If u really need it decrease the density urf (0,2-0,5) the pressure URF (0.05-0.2) and the momentum URF (0.4-0.6). For the p-v coupling start with the SIMPLE.
Thomas
difference between ideal gas & boussinesq approach meda Main CFD Forum 3 September 15, 2020 14:53
Setting initial amount of ideal gas David FLUENT 0 November 2, 2007 08:35
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Fluent journal - setting ideal gas Franky FLUENT 6 May 2, 2006 04:21
unstructured grid sreekanth Main CFD Forum 1 August 6, 2001 15:09
