using DEFINE_ADJUST to calculate source term
Old   March 30, 2006, 04:02
Default using DEFINE_ADJUST to calculate source term
shuqin
hi every! I want to add some calculated values as source term to species transport equation and I settle this by employing DEFINE_ADJUST to calculate the value and store it in udm ,and then retrieve it in DEFINE_SOURCE,ACCESS VIOlATION error came out,and when only use DEFINE_ADJUST to calculate the value and store it in udm without evaluating in DEFINE_SOURCE ,I can plot the conters of the udm,why I cannot use it in DEFINE_SOURCE? Any suggestions?
Old   March 30, 2006, 20:17
Default Re: using DEFINE_ADJUST to calculate source term
KP
Did you allocate memory properly? KP
Old   March 30, 2006, 20:33
shuqin
yes,I did,I can even plot the contours of udm when not retrieving in the DEFINE_SOURCE. but anyway,thanks for your attention!
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 14:21
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Adding a momentum source term segersson OpenFOAM Running, Solving & CFD 5 March 2, 2006 23:06
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
