cannot open fluent
Old   March 25, 2006, 18:28
Default cannot open fluent
Alex
I'm trying to open fluent using the visual .net 2003 command prompt (in Windows XP), but I can only open fluent by going into the directory where it is installed.
I want to build and compile a UDF in fluent, but in order for it to recognize the file and not give me the "cannot open lib_udf_library" message, I need to open fluent from the directory where I have my case file and source file.
I have tried copying the case and source file directly into the ntx86 directory where the fluent.exe is installed. It lets me build the UDF file, but i still get the cannot open libudf error when I load it.
can anyone help me??
Old   March 25, 2006, 22:15
Default Re: cannot open fluent
AK
Make sure that you have correct path so that Fluent is recognized command.
Once you are in visual.net prompt, cd to the directory where you have your files and then launch fluent from command prompt.
Hope this helps.
Old   March 25, 2006, 23:59
Alex
thanks for the reply. I managed to find the solution. I had to set the environment variables for Fluent first. At first it didn't work but then I rebooted the Pc and now it works just fine.
Cheers
Alex
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
[General] Paraview: open fluent 13-files podracer ParaView 1 November 23, 2011 07:55
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
where to open the file jx FLUENT 0 February 19, 2004 12:19
