why can not two udf.s be used?
Old   March 28, 2006, 02:07
Default why can not two udf.s be used?
wanghong
Hi! i want to model a melt and VOF process, need to use heat flux'udf and momentum source term'udf at the same time,but after they are compiled,it appears following errors:
Error: chip-exec: function "cell_z_source" not found. or
Error: chip-exec: function "heat_flux" not found. can FLUENT only use one udf? how to use two udf at the same time? Thanks!
Old   March 28, 2006, 05:32
Default Re: why can not two udf.s be used?
Kharicha
print your source to see if there is a mistake...
Old   March 28, 2006, 08:11
ayapan
is it necessary to use two udf's?
you can write all in one udf and hook where ever you want
bye
Old   March 28, 2006, 15:05
Allan Walsh
Are you using V6.2? or earlier version? V6.2 seems to be fine with multiple udf libraries.
Old   March 28, 2006, 20:37
wanghong
I am using V6.2. may i write one heat flux source term and one z axial momentum source term in a udf file?
Old   March 29, 2006, 14:59
Allan Walsh
Sure. Make sure each each one works though.
