questions about udf
Old   April 4, 2006, 02:47
Default questions about udf
Lobby.H
Hi everyone
The model i'm solving has a souce term in N-S formula and this source term concerns an user defined scaler n which is decided by equation below: dn/dt=-div( n(U+Vc) + Di* div.*n ) 'cause i can't find the sign for partial differential, dn/dt was used instead. U is velocity vector, Vc is a constant and Di is the diffusivity constant. i wrote a define_source udf for N-S formula and an uds_unsteady, an uds_flux, an diffusivity for the equation above.
question 1: will the 4 udfs above be enough? what other udfs should i employ? i.e. define_adjust or something?
question 2: How can i initiate scaler n? use define_init or just set in panel?
question 3: i've set the boundary conditions as walls. will these b.c. work with n? or should i employ define_profile?
question 4: the udf for diffusivity i set will return a constant. but i wanna know will it be calculated in uds? will it be wrongly calculated in N-S?
Thanks in advance. These problems already troubled me for some days.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Help,I have some questions about UDF of mass diffusivity in fluent apolloking Fluent UDF and Scheme Programming 0 March 20, 2011 11:40
So many questions in DPM & UDF - Help! URGENT! Prashanth FLUENT 0 March 3, 2009 22:26
UDF: Some Questions Nirupam Rohatgi FLUENT 0 December 18, 2007 05:55
Unsteady UDF Questions hirokata FLUENT 0 July 8, 2006 13:32
