node distance from wall??
Old   April 5, 2006, 17:37
Default node distance from wall??
Fluuuent
hello
the mesh generator used by airpak. when we refine the mesh locally on the surface, is the element height, the full height of the cell or is it the height till cell-node from surface
anyidea what to use for reference length (for the Re #), in order to approxiate the y+ value using a y+ calculator
thanks
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
calculate distance from wall to neighbourig cell centroid rr123 Fluent UDF and Scheme Programming 39 March 14, 2017 01:41
Bug in wall distance calculation david OpenFOAM Bugs 3 March 15, 2011 09:32
distance between particle and wall Worth FLUENT 2 June 13, 2009 03:04
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
