Paralel Network Bottleneck?
Old   April 4, 2006, 18:34
Default Paralel Network Bottleneck?
Riaan
Dear all,
I am currently running 6 CPU's in paralel using the NET protocol. After 4 CPU's, I do not see any additional speed-up in time per iteration.
I switched to NMPI/Metis Partitioning, but this just made it run the same/slower.
The 6 CPU's are 3 Dual CPU machines, each with 4gb of ram, and on a gigabit network. We do not run out of ram/cpu on any of the machines.
Right now the cases are 3 million cells, steady segregated, 2nd order,Realizable K-Eps, and take about 25 seconds per itteration on the 6 CPU cluster...
Some advice please ~?!
Old   April 7, 2006, 19:34
Default Re: Paralel Network Bottleneck?
Andrew
I have noticed a similar problem with my simulations. My explanation (and I am no expert on the subject), a large amount of time is taken juggling data around between each computer node once you get above 4 CPU nodes.
Here are the stats that I found for my particular case:
I based efficiency on (CPU-time/Number of CPU's)/Wall Clock, also DT data transfer per iteration:
1 Node: 99.9873% 2 Nodes: 97.9519% (DT=0.025MB) 4 Nodes: 86.1218% (DT=0.063MB) 8 Nodes: 69.923% (DT=0.306MB) 16 Nodes: 40.512339% (DT=2.743MB) 32 Nodes: 16.906626% (DT=11.6MB)
I get around this by running a parallel version of Fluent 8 times, each taking 4 nodes.
Andrew
Old   April 7, 2006, 20:55
Riaan
Yip, my problem is that I only have access to a single license, with 6 parallel licences.
IcePak network objects in parallel solver Alexey FLUENT 1 December 25, 2013 08:32
48 Core Cluster - GigE Network ronaldalau Hardware 2 September 9, 2011 13:50
Problem whith parallel an network configuration agamezcfdof FLUENT 0 June 30, 2009 10:51
Initialization of fluid network Liang Huang Main CFD Forum 0 September 23, 2004 03:10
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
