Installation Problem
Old   April 22, 2006, 12:34
Default Installation Problem
Meenu
hi, I installed gambit & fluent on a new computer but I'm not able to use the help in that. Whenever I click help it says: NO HELP AVAILABLE FOR ......(for which I need help).I have not given any spaces in the folder names as I know Fluent doesn't like that.Let me know there can be some other reason for this.
Thanx.
Old   April 22, 2006, 14:26
Default Re: Installation Problem
ashish
i had this problem when i installed fluent in windows. i solved the problem by placing the help files in the appropriate folder in Fluent.Inc directory. you can check the folders in Fluent.Inc directory, you will know where to exactly keep them.
Old   April 22, 2006, 14:29
Meenu
hello Ashish
Thanx. Now I can use the help. I found out what mistake I was making.
Meenu
OpenFOAM-2.0.1 installation problem benru OpenFOAM Installation 1 September 14, 2011 09:15
/Allwmake Problem During Installation of OpenFOAM-2.0.0 MPD78 OpenFOAM 0 July 26, 2011 08:38
Installation problem for 64-bits system Chande FLOW-3D 1 March 27, 2011 17:59
OpenFoam-1.6.x installation problem vsnprasad27 OpenFOAM Installation 1 August 21, 2010 04:35
Installation paraFoam - still problem nhl OpenFOAM Installation 7 June 22, 2010 09:22
