BC's details unavailable from imported msh file |
April 19, 2006, 14:40 |
Dear chandra and zxaar
as per the advise received from you, In Gambit I had imported *.msh file from fluent *.cas file. But the boundary conditions details are not available in the *.dbs file? how will I get the boundary condition details in the dbs file so that I can edit the bc's and export new msh file for fluent run. |
April 19, 2006, 18:09 |
Re: BC's details unavailable from imported msh fil
when you extract mesh from .cas file as i mentioned the boundary conditions are available.
April 20, 2006, 01:06 |
I get the following error: is this a very serious error, please help.
Starting /pkgs/gambit2.0/Fluent.Inc/utility/fe2ram4.3/ultra/fe2ram.4.3.2 -m1e-06 -d3 -tRAMPANT -oFIDAP7 /home/ashish/3dmodel.cas.tar.cas RAMPANT file to FIDAP7 file Read 1994678 nodes, 1868000 elements, 14 groups. 1868000 hex elements merged 0 nodes (1994678 remain)ERROR() error code = 101077 WHERE = -?- ERROR() error code = 101077 WHERE = -?- Thanks a lot. |
April 20, 2006, 04:30 |
why is the model compressed, uncompress it and see if it changes anything. Anyway it should have already worked i guess.
April 20, 2006, 08:06 |
I will try and get back.
April 23, 2006, 04:29 |
Hello zxaar,
the boundary conditions are available in the mesh file, but when i import the mesh in gambit i do not see the boundary conditions details, can you please help. thanks. |
April 23, 2006, 06:47 |
Hello zxaar
one more thing which i found was when i read the msh file thus obtained as above and read in fluent i find that the zone id's have changed and when i solve i get the Floating Point Exception (Underflow) Error. this was not the case with the original fluent case file. can you please help. thanks, ashish. |
April 24, 2006, 06:56 |
if you use the latest version of gambit, you will see it preserves the boundary condition names as they were.
April 24, 2006, 07:24 |
#9 |
use journal file to describe the boundary conditions etc, when you describe BCs by TUI you can just use their name to specify the BC, you do not need the zoneid, let it change.
April 24, 2006, 08:13 |
#10 |
i specified the bc's in gambit and exportet the mesh, but while solving in fluent i get the error. where as the original case file does not give any error.
please help. regards, ashish. |
April 24, 2006, 08:45 |
#11 |
you haven't told what error it gives.
April 24, 2006, 11:26 |
#12 |
Hello zxaar
I though that you have read my earlier message in this thread: "one more thing which i found was when i read the msh file thus obtained as above and read in fluent i find that the zone id's have changed and when i solve i get the Floating Point Exception (Underflow) Error. this was not the case with the original fluent case file. can you please help." thanks, ashish. |
April 24, 2006, 18:14 |
#13 |
i also thought you have read my other message, See when you read the mesh, and if you do not want to describe them again and again manually. describe them with the help of journal file. If you do this way, you do not need to worry about zoneid, you can specify by their names. So create a journal file to do the work for you. I will put and example here, or on wikipedia in FAQ section today.
April 24, 2006, 21:26 |
#14 |
Here is an example of journal:
define boundary-conditions velocity-inlet inlet n n y y n 10 y n y 0 0.001 define boundary-conditions pressure-outlet outlet n 101325 n n y n y 2 0.001 n define boundary-conditions fluid rotzone n n n n n y 0 0 0 -50.00 0 0 0 0 0 1 n n n put these things into a journal and read the journal, you can note that i have not used the zoneid but the zone name, inlet and outlet, |
April 25, 2006, 00:08 |
#15 |
thanks for your journal. i will use this and get back.
regards, ashish. |
April 25, 2006, 01:14 |
#16 |
you might have to create your own suitable to ur case, its easy to do it.
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
