Linear Temperature Profile
Old   April 24, 2006, 16:23
Default Linear Temperature Profile
Ferdous Rana
I am a newbie in CFD and doing calculations on a closed cubic cavity. The top wall is defined as cold and the bottom wall is hot. Now I want to define linear temperature profile around the four side-walls. How to input linear temperature profile ? Please help.
Old   April 24, 2006, 16:51
Default Re: Linear Temperature Profile
Joe
You can use either a UDF for boundary profiles to achieve this. Check out the Fluent UDF example on specifying a parabolic inlet profile. Your problem could simply follow a similar structure.
UDF for linear temperature profile across the hemispherical surface tshv247 Fluent UDF and Scheme Programming 1 October 3, 2011 12:44
Appling a linear temperature profile to a surface safikhani_hamed FLUENT 0 December 8, 2010 14:59
Help please! UDF for Temperature profile in 3D subhankar_bhandari Fluent UDF and Scheme Programming 2 August 16, 2010 08:37
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
temperature profile on boundary sivakumar FLUENT 5 November 24, 2002 00:58
