May 5, 2006, 07:20 |
Urinal Problem
I am currently trying to model a stream of urine splashing off the inside surface of a urinal in 2d. Does anyone know how to model a jet of water hitting a surface and splashing back off the surface under gavitaional and atmospheric forces?
Any help would be much appriciated. Cheers Adam |
May 5, 2006, 09:59 |
Re: Urinal Problem
I believe u need to do VOF analysis for the break up...
May 5, 2006, 10:05 |
Re: Urinal Problem
Could you describe what you mean in more detail. and how do I setup my container that the experiment is contained within to have air at atmospheric pressure in it?
May 5, 2006, 10:19 |
Re: Urinal Problem
i have not done VOF study yet, however u should focus on the break up section which is quite complicated. u should know the inlet velocity profile of urine to ur control volume. U can safely assume stagnant atmosferic conditions in a bathroom, also u can ignore mass and energy transfer between urine and air, and that should simplify ur case a bit. good luck
May 5, 2006, 11:02 |
Re: Urinal Problem
I would suggest you read the tutorial regarding the ink jet coming out from the nozzle. Then you could adjust the problem accordingly. To get this tutorial online, log on Fluentusers.com
May 5, 2006, 11:17 |
Re: Urinal Problem
Where do you find that? If it is not online could you possibly email it to me at: adamjackson1606@aol.com
I am not registered for the fluent website as I am using the program at my university. Thanks for you help |
May 5, 2006, 12:34 |
Re: Urinal Problem
CAn u send me the geometry of your probleme i think that i can help u, you ll work withe the VOF methode
May 5, 2006, 13:09 |
Re: Urinal Problem
Drink 12 pints of Guinness, go to your nearest wall and watch what happens. Nothing like real experimentation to satisfy your curiosity and see VOF in action.
May 5, 2006, 15:30 |
Re: Urinal Problem
#9 |
Posted By: Father Jack Date: Fri, 5 May 2006, 11:09 a.m. In Response To: Urinal Problem (Adam Jackson)
Drink 12 pints of Guinness, go to your nearest wall and watch what happens. Nothing like real experimentation to satisfy your curiosity and see VOF in action. That is GOOOOOD!!!!!! ))))))) |
May 5, 2006, 16:58 |
Re: Urinal Problem
#10 |
Why don't you also use FSI for constipation ?
May 5, 2006, 18:17 |
Re: Urinal Problem
#11 |
lol
May 10, 2006, 10:30 |
Re: Urinal Problem
#12 |
If you'll pardon the pun, should be a piece of p*ss.
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
